Door seal problems
Old Oct 22, 2005 | 04:23 AM
78-f150-4x4-351m's Avatar
78-f150-4x4-351m
Door seal problems
I bought some new door seals off E-bay that are supposed to be for my truck (78 F150). I installed them 3 months ago but they seem to thick. I still have to slam my doors to get them to shut all the way. Any suggestions or thoughts.
Old Oct 22, 2005 | 08:08 AM
garypettengill's Avatar
garypettengill
I put new seals on my truck a long time ago and to this day if all the windows are closed the doors require extra effort to close. Really all you can do is ensure that all the adjustments possible for the hinges and the latch assy are correct and don't pull too hard on the door cups as if they are plastic they will crack.
Old Oct 22, 2005 | 08:22 AM
satx77stepside's Avatar
satx77stepside
What brand (or ebay seller) were they? (So that others know to be careful)
Next time try dennis carpenter, I know the price is higher than a lot of kits, but this is something I plan to spend the extra $$$ on for the quality.
Old Oct 22, 2005 | 10:26 AM
78-f150-4x4-351m
The brand of seals is Metro "Supersoft Sponge". Metro is in Minnieapolis, MN and the Ebay Seller is 1AAutomotive.com. The label on the box said 73-79 Ford Truck & 78-79 Ford Bronco.
Old Oct 22, 2005 | 10:28 AM
78-f150-4x4-351m
Is it normal for the doors not closing easy for awhile even with a quality seal or has anyone had the experience of them closing good from the start.
Old Oct 22, 2005 | 10:45 AM
78-f150-4x4-351m
I just called 1A Automotive and they said I may be able to adjust the door latch the catches the strike pin about 1/4" to get it to work. They were very polite. I try it and see if it works.
Old Oct 22, 2005 | 11:42 AM
78-f150-4x4-351m
Adjusting the door latch did not work. They told me to loosen up the 3 big screws and it would adjust. I couldn't get it to adjust. However I did fix the problem. When I bought the truck there was electrical tape wrapped around the door strike pins on the cab. When I was painting the jambs I took the tape off. My wife suggested putting the tape back on. I did. Now the doors close fine. I guess the closing mechanism wears down over time allowing for some play causing the door not to grab the strike pin. I guess its time to replace the closing mechanism on the door. I don't like the fact that I have electrical tape fixing a problem even though my truck looks like crap on the outside, I have done a damn good job on the interior. Many thanks to my wife. Now I have time to work on her 71 Fastback today.
Old Oct 22, 2005 | 11:38 PM
toogaw's Avatar
toogaw
I Just replaced the cab door seals on my 79 f-100, got them through LMC Truck, they fit nicely , my doors were also hard to close for about the first week, but as the seals get formed to their new position, the doors are getting much easier to close.
Old Oct 23, 2005 | 12:04 AM
4starcstms's Avatar
4starcstms
you can adjust the striker out (the part that has the Torx bit on it in the jamb) your latch itself wont adjust, they must be thinkin of chev or something else. I bought mine from Dennis C and mine are also hard to close, had to adjust the striker out a bit.. not to much as you still want them to be tight..
Old Oct 23, 2005 | 08:35 AM
2tone73's Avatar
2tone73
Maybe you just need some rust holes in your floorboard to help the release of pressure inside the cab. Like on most ford trucks. Its pretty cool in the summer, no need for ac with all of those rust holes!!!!!!! Funny
Old Oct 23, 2005 | 11:44 AM
bushman's Avatar
bushman
All of the weather seals I used on my 79 were directly from Ford. It has been just over a year and they are just now starting to form so the doors will close easier. Should be great in another year!!!
Bushman
Old Oct 23, 2005 | 12:39 PM
yield2s's Avatar
yield2s
You can get a new strike pin at most parts stores for under 10 buck. origanally theres a white plastic filler where you put the tape but it breaks eventually.Its common,just replace it and the door will close right.
Old Oct 23, 2005 | 02:45 PM
Mil1ion's Avatar
Mil1ion
They will eventually be fine,once they get somewhat weathered.
Old Oct 23, 2005 | 03:51 PM
dakonthemountain's Avatar
dakonthemountain
Yup to all the above. I put mine on 2 years ago and it took almost a year before I didn't have to slam the doors; even after adjusting the striker pin. Problem was worse when I first replaced them because it was in winter. First warm spell helped.
Good luck
Dak
Old Oct 24, 2005 | 01:40 AM
Purely Ford's Avatar
Purely Ford
Just head to the salvage and get some pins from just about any 70s Ford car or truck. Just take the old one with you to compare. I have some from a 1972 Gran Torino which are identical to the type in these trucks.
