Door seal problems
Old Oct 26, 2005 | 05:18 PM
78-f150-4x4-351m's Avatar
78-f150-4x4-351m
Darn, that probably would have done it. Too bad I just replaced the floor pans. Ha ha.
Are you really Dr. Wu? ---Steely Dan
Old Oct 26, 2005 | 05:21 PM
78-f150-4x4-351m
Thanks for everyones help.
We can do that. We don't even need a reason. --- Carl Spackler
Old Oct 26, 2005 | 11:26 PM
Mil1ion's Avatar
Mil1ion
Just a head's up !
All users Have 60 minutes to edit their own posts if they care to add or remove content
Old Oct 26, 2005 | 11:56 PM
roushracing617's Avatar
roushracing617
Wink
Good info. as mine need replaced. Thanks guys!
Old Apr 27, 2006 | 12:17 AM
Toothman's Avatar
Toothman
One more thing you can use (which was done on mine) is just cut a small piece of hose. It's tight at first but will get easier with use.
Old Apr 27, 2006 | 01:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
The door strike pins are easy to get and last for many years. I have messed with hose and tape but in the end it is much simpler to just do it right the first time.
After seal replacement it is necessary to adjust the hinges as well as the strike. It is sometimes also necessary to adjust the fenders, -it is not hard to do. After the adjustments are made the doors are easy to close and the seals will last much longer.
Old May 1, 2006 | 09:50 PM
trinogt's Avatar
trinogt
When these trucks were new, ya didn't have to slam the doors... maybe cause they sat for a while with the doors closed? Maybe Ford had a trick up their sleeve???
Mark
Old May 1, 2006 | 10:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just like I said above, the doors were adjusted properly from the factory. Some needed a tweak at the dealership tho. With new seals they will need to be adjusted again. It really is very simple, no need for door slamming and your seals will last a lot longer. I have done this hundreds of times over the years on all types of vehicles, no magic or tricks involved.
Old May 1, 2006 | 11:02 PM
trinogt's Avatar
trinogt
Yeah, but you still want your doors fitting flush with the sheetmetal on the outside, not sticking out catching air? That is how I adjust my doors; I don't adjust for weather strip... Guess I'm just lucky?
I guess you could adjust the fenders as far as the front fit goes, but if the rear fits flush and weather strip is tight, you still have to slam, or have the door stick out some with the striker adjustment to compensate for the weatherstrip.
Mark
Old May 2, 2006 | 01:41 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is enough adjustment range in the weatherstrip configuration to avoid any uneven doors or doors sticking out. The biggest problem people have is the doors on these old trucks have been adjusted and tightened over the years for wind noise and/or rattles from worn latches. When the rubber seal is finally replaced people forget to readjust the door outward which results in "door slam" problems. This is really no big deal and it is simple to do in most cases.
The hardest "adjustment" to make is if the door has been "tweaked" to increase the force on the top of the door and having to "un-tweak" the door which requires some padding and a block of wood. Again it is not difficult to do it just takes some time, patience, and sometimes a little "intestinal fortitude" in lieu of experience.
Old May 2, 2006 | 11:33 AM
Mil1ion's Avatar
Mil1ion
I think the replacement weatherstripping we purchase today is made slighly different than the OEM installed back in the 70's.
I was smart enough to buy my OEM replacement W/S back in the 80's expecting someday to having to replacement it.
It's been sitting nicely in a hermetically sealed envelope since then
Old May 2, 2006 | 02:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
The new one I have, except for both being deformed, looks just like the one on the door now. That rubber strip will still get hard with age in a bag.
Old May 3, 2006 | 03:58 PM
  #28
1BigFish's Avatar
1BigFish
I've used silicone spray for years with good results. You can spray down a cloth and wipe it on the rubber and door surface. Works great!
AMF!
Old May 3, 2006 | 05:19 PM
  #29
trinogt's Avatar
trinogt
Yeah, Fish, silicone is good for rubber conditioning, just like with windshield wipers... (yeah, I actually DO treat my wiper rubber with silicone! Along with door seals, on all my cars.) I have never had to replace weatherstrip except for vehicles that I bought with missing or broken stripping. Cars I have had for many years still seal well, and seals are pliable.
Mark
Old Feb 13, 2009 | 09:34 AM
  #30
ExForBrian's Avatar
ExForBrian
for a few bucks the auto parts store has them new. why go looking for a used striker?? as for the door closing hard. do this, take WD-40 and spray the mechanism on the door real well, then slam the door, then open the door, then slam it again, then open then slam, over and over 10 to 15 times, then let sit for 15 minutes, and spray again, and repeat the slamming, you will then notice that the dirt and rust that gets in the lock will loosen up and you will be able to open and close it with ease.. my truck has 57K original miles, and no rust, (souther truck) and it was never lubricated, so after I did this I found that it works like it should. remember this is not a 2009 f150, they made them different back them, strong!!! LOL
bb65f1004x4
15
May 5, 2014 12:04 PM
Wbruiser2
May 22, 2013 02:58 PM
oem78
Jun 29, 2009 05:55 PM
Holmsey
16
Apr 11, 2008 02:52 PM
spikedog
1997 - 2003 F150
Dec 29, 2004 10:27 AM
