88 f250 7.3 diesel fuel pump
Old 10-21-2005, 11:02 AM
muddermike's Avatar
muddermike
muddermike is offline
How do you turn the fuel pump up on a 1988 7.3 diesel to give more power.
Old 10-21-2005, 11:06 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 10-21-2005, 01:14 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
This was covered on this forum a couple of months ago. Search the forum. You are looking for "Fuel injection pump adjustment article". From what I remember the adjustment screw is inside the pump accessed thru a door on the passenger side of the pump.
Old 10-21-2005, 02:18 PM
RawPower's Avatar
RawPower
RawPower is offline
Above is correct. its a 5/32" allen wrench screw that is inside a small "door" that is shaped like a pentagon. lots of fuel will come out when you take this cover off. also, you will probably have to turn the engine over to get the screw lined up with the window-hole.
Old 10-21-2005, 02:52 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
And then your engine will smoke like Hell for a while. It will stop though...when your pistons melt.
Old 10-21-2005, 05:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
muddermike, do you have any black smoke under hard accelleration now?
If you do, you will just be wasting fuel to turn it up more.
The article refferenced above will state a little turn on the screw is a lot more fuel.
One flat of the allen screw will probably be more fuel than it can burn.
If you have any black smoke at all now, I would not go through the trouble to turn it up. You will probably have to re adjust it back down if you do. Everybody seems to turn it up to much when they do it the first time. Then the air police are mad at you for all the clouds of black smoke and wasted fuel.
If you want to increase the power, you would be better off to work on the exhaust and air intake areas before you adjust the injection pump. With better air flow in those areas you will be able to benifit more from the increased fuel.
Old 10-22-2005, 05:07 AM
bilder12's Avatar
bilder12
bilder12 is offline
its always kewl to let ppl know that you got a diesel BUT
more respect is shown when they are clean burning. As Dave stated above, if you have a light haze of smoke on hard pulls, you are getting enough fuel for the engine to burn efficiently. Work on getting it to breathe better and you will have more benefits and money in your pocket.
andrewjdouglas
29
07-08-2016 01:09 PM
jmuenchow
09-26-2015 12:14 PM
'94IDITurbo7.3
25
03-16-2012 12:36 PM
steeltaber
04-10-2011 08:33 PM
mrmetro99
03-23-2011 09:24 PM
Quick Reply: 88 f250 7.3 diesel fuel pump
