ABS light '00
Old Oct 21, 2005 | 08:40 AM
pounder90's Avatar
pounder90
ABS light '00
My ABS light is staying on. I plan to replace the sensor on the rear diff because it seems like the most common failure. Any suggestions?
Thanks
Old Oct 21, 2005 | 06:28 PM
bobfl's Avatar
bobfl
That solved the problem on my 99 XLT. Very simple job only took a few minutes. Just clean around the old sensor before you take it off.
Old Oct 24, 2005 | 10:15 AM
pounder90's Avatar
pounder90
Thanks Bob, it worked. I measured the resistance on the pins of the old VSS. The signal was open. The new part had a resistance of 1.9 MOhm. I bought the VSS from the dealership for $22. Autozone wanted $44.
