1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
08 F250 6.4 wont start hot -cold runs fair
Old 06-17-2010, 08:13 PM
Corvette95's Avatar
Corvette95
Corvette95 is offline
Low mileage F250 . Got a check engine light then wrench light then BOTH went away and ran ok. Came back on yesterday on 65 mile trip home. Had to make one stop, 30 minutes later came back to truck tried to start...crank...no start---wanted to but didnt. Towed it home on flatbed. This morning after sitting overnight, started fine, but check engine light (no wrench), drove to work, buddy had OBD2 generic scanner, said two codes both fuel rail pressures low. Then with it hot, no start again. Its gonna go to the dealer I guess. I dont mind paying them, but last time they had it for a oil change and fuel filter change and tire rotation they put a HUGE dent in the hood from raising it on the lift with hood open and hood hit lift beam, I had it paintless dent repaired but still made me mad so now I try to avoid dealer. Any thoughts? Is this a common problem? I have always driven GMC's.
Old 06-17-2010, 08:37 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
sounds like either EGR or fuel pump related. What were the exact codes? Sensors that is.
Old 06-17-2010, 08:39 PM
Corvette95's Avatar
Corvette95
didnt write down the powertrain code numbers but it said
either right and left or front and rear fuel line pressure low
Old 06-18-2010, 05:23 AM
senix's Avatar
senix
senix is online now
This may have been the code:
P0087 X X Fuel Rail/System
Pressure - Too Low
This error will be set if the fuel pressure in the rail is too
low and the controller cannot regulate it to the setpoint.
20 % “overposition” of the
PCV or VCV [% PWM]
5% deviation of the fuel rail pressure
to the fuel rail pressure setpoint.
Low pressure system, wiring to
VCV and PCV, FUP sensor, pump
Old 06-08-2020, 08:07 PM
Lawn Rangers's Avatar
Lawn Rangers
Lawn Rangers is offline
hot start
did you ever figure out the problem? I'm having the same issues. it stalled today an wouldn't start got pulled home soon as I got here it fired right up
Old 07-07-2020, 04:19 PM
Estephan William's Avatar
Estephan William
Estephan William is offline
same here it’s a fuel temperature issue
hard to compress to 5000 psi when it’s 180 degrees
what did you find out
Old 07-07-2020, 08:20 PM
senix's Avatar
senix
senix is online now
If it dies and won't start but does a few minutes later my first thoughts would be EGT 14 sensor.
Old 08-13-2020, 01:04 PM
VVerdugo116's Avatar
VVerdugo116
VVerdugo116 is offline
What should the temperatures be on the egt sensors?
Old 08-13-2020, 02:11 PM
senix's Avatar
senix
senix is online now
They would al parallel each other.
When cold, before a start see what they all read. If the motor is cold, I would expect them all to read ambient temps.
beidle99
2009 - 2014 F150
05-07-2017 05:18 PM
moctx
6.4L Power Stroke Diesel
12-10-2015 10:10 AM
ryanbodden2014
12-26-2014 02:19 PM
Vinford
27
07-14-2014 10:57 AM
BroncoEx
36
10-27-2012 09:34 AM
Quick Reply: 08 F250 6.4 wont start hot -cold runs fair
