Foam in valve covers
Old May 15, 2002 | 10:23 PM
proford460's Avatar
proford460
Old May 17, 2002 | 10:43 AM
KJKozak2's Avatar
KJKozak2
I swear I saw a post about this but my searches here and in the big block forum turned up nothing.
I have a 78 F150/460 4x4. Last night I pulled the PCV valve out so I could get a funnel into the tranny tube, and the valve seemed to have foam on it. I had just run the engine for about 10 minutes.
So, in general, what causes foam in the valve covers?
Thanks in advance!
Kevin K.
Old May 17, 2002 | 10:57 AM
BB's Avatar
BB
Running the engine for 10 minutes.
Try running it for 30 or so minutes and then check it out. If the T-stat and PCV are ok then it should be gone.
Barry
Old May 17, 2002 | 11:27 AM
beartracks's Avatar
beartracks
Normally water but it might just be condensation. Do as the last post said. After it gets hot it should evaporate.
Bear Tracks
Old May 17, 2002 | 11:33 AM
KJKozak2's Avatar
KJKozak2
Thanks for the replies!!! I'll run her around tonight and see what happens.
Kevin K.
