Rubber mat between camper and bed ?
Old 10-19-2005, 06:07 PM
fmcdoug
fmcdoug is offline
fmcdoug is starting off with a positive reputation.
Does anyone have any thoughts on whether or not it`s a good idea to use a rubber bed mat between a slide in camper with a 1 1\8" spacer and the truck bed ?
it seems to sway, or rock around more than the previous truck with a spray in bed liner that I use it on .
Thanks , Doug
Old 10-20-2005, 03:33 PM
jimandmandy
jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
I put my slide-in right on top of a regular bed liner with no problems. The camper manufacturer recommends against it, but when I called them, they could not give me a reason why.
Jim
Old 10-23-2005, 07:55 AM
Wrenchtraveller
Wrenchtraveller is offline
Wrenchtraveller is gaining momentum as a positive member of FTE.Wrenchtraveller is gaining momentum as a positive member of FTE.
I always use a rubber bed mat with a slide in Camper. It keeps the camper from moving and I don't believe the mat would increase your sway. Mine is 1/2" thick hard rubber and it does not compress enough to effect handling IMO.
I also use a wood spacer at the front bottom of the bed and this keeps the camper about 1/2" back from the top bed rail which bends very easily if your camper ever shifts.
I had a camper do that in one of my previous trucks.
Old 10-24-2005, 08:38 AM
Toyman's Avatar
Toyman
Toyman is offline
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
A rubber bed mat is fine it will help the camper from sliding around in the bed. The plastice drop in bed liners are not recommended do the surface being as slippery as it is. When I deliver a truck camper to a customer, and they have a plastic liner I recommend to put a bed mat between the camper and the box.
Toyman
Old 05-15-2017, 09:19 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Glad I searched and found this thread before asking a similar question. I have a rubber mat type and will leave it in.
I agree on not using a plastic type.
Old 05-16-2017, 07:01 PM
WyoBull's Avatar
WyoBull
WyoBull is offline
WyoBull is gaining momentum as a positive member of FTE.
I would not carry a truck camper without the rubber bedmat between the camper and the bed. Not only does it keep the camper from sliding around but also keeps it from wearing from sitting directly on the bed. That's just my opinion though but my dealer definitely recommends having a rubber mat in the bed.
Old 05-17-2017, 07:46 AM
stufarmer
stufarmer is offline
stufarmer is gaining momentum as a positive member of FTE.stufarmer is gaining momentum as a positive member of FTE.
I went to my local Farm & Ranch Supply store and purchased a Horse Stall Rubber Mat for my truck bed.
I've also always used Happijac Front TieDowns for my Campers.
They are the only ones I've found that keep the Camper secured against the front of the bed.
Lance Camper offers Ft bumpers you install at the Base of the Camper. They Keep the Camper the perfect distance between the Ft of the Camper and the Bed.
Old 05-18-2017, 04:39 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Just got back from an 800 mile run to pick up our new to us Hallmark slide-in. Rubber mat was in place the entire way as we discovered once we got there that Torklift turnbuckles were too long for the front and too short for the back so we had to resort to using standard turnbuckles and feel the bed mat helped limit movement.
Steve
Old 05-21-2017, 11:21 PM
skanj0
skanj0 is offline
skanj0 is starting off with a positive reputation.
Another vote for stall mat. I found a 4x8 sheet and cut it to fit. Works great for truck campers. Also gives the camper a tad more clearance over the top of the cab.
In terms of keeping the camper from moving forward and denting the front of the bed, I finally came up with a solution that works great. I bought a piece of 3"x4"X1/4" steel angle, and drilled it to accept the front two bed bolts. I then got 2 bed bolts that were 3/4" longer. I then had the angle sprayed with Linex seperately when they shot my bed. Here is a pic. It works awesome, and no more screwing around with lumber to try and protect the front of the bed. It really helps - especially off-road.
Old 05-22-2017, 06:35 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Functional and looks sanitary. looking. Good idea!
Steve
Old 05-22-2017, 08:15 PM
skanj0
skanj0 is offline
Steve
Thank you, Sir. Appreciate the feedback.
Old 05-11-2018, 10:58 PM
spudthegreater's Avatar
spudthegreater
spudthegreater is offline
spudthegreater is starting off with a positive reputation.
I use a rubber mat and because i need the cabover clearance i use an 8x4 2" Blue styrafoam sheet . it does not compress like you might expect , and it helps prevent the cab over porposing, that i had without it . Compression per square inch is way more than the camper weight. So no worries.
3rdfordtruck
2017+ Super Duty
01-06-2018 11:15 AM
DRKBC
2017+ Super Duty
11-27-2017 08:36 PM
Smokey X
2017+ Super Duty
15
09-30-2017 08:36 PM
GuinnJ
2017+ Super Duty
10-03-2016 10:26 AM
doczenith1
6.7L Power Stroke Diesel
07-21-2016 04:42 PM
Quick Reply: Rubber mat between camper and bed ?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
