Where Are You?
  #151
Old 10-27-2005, 06:06 PM
Brian_B's Avatar
Brian_B
Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
Here is the link again for those who missed it. Only 91 members are on it so far.
http://www.frappr.com/oldfordtrucks
The huge hole still exists in the midwest.
  #152
Old 10-27-2005, 06:35 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
OLDFORDS..found it, can't tell from the picture, did you use a complete I-beam frame or just the front section???
  #153
Old 10-27-2005, 07:48 PM
OldFords
OldFords is offline
OldFords is starting off with a positive reputation.
hiball... I removed everything I needed from a later-model F100 (around 1976) that had Twin-I-Beams and disc brakes. This inluded the crossmember, spring towers, etc.
I removed the crossmember and straight axle from my '59 and replaced it with the Twin-I-Beam stuff. I didn't use the original I-Beam axles - went with dropped I-Beams. I fabricated adjustable frame brackets to support the radius arms so I could move the caster about 5 degrees plus of minus.
I also used the portion of the donor frame that held the power steering box, so I could install a 1970 Bendix unit I had laying around. I welded it in at the back of the crossmember just as it was in the donor truck. Withthe 429 ci I have about 1/2" between the exhaust manifold and the steering box.
I'm expecting to have several pictures of the modifications on this site in the not too distance future. A couple of the forum gurus have volunteered to help me set up a gallary.
OldFords
Bad Attitudes
  #154
Old 10-27-2005, 08:47 PM
55FordLover
55FordLover is offline
55FordLover is starting off with a positive reputation.
El Paso, TX here....just 12hrs from dallas and 8 hrs from san antonio....4 hrs from tucson, az
  #155
Old 10-28-2005, 07:21 AM
hiball3985's Avatar
hiball3985
OLDFORDS...thanks, I will be looking foward to seeing more on this swap, something I have always thought about..I love the twin Ibeam in my 66 and always thought about how it would work in my 60...
  #156
Old 10-28-2005, 08:32 AM
SteV8e's Avatar
SteV8e
SteV8e is offline
SteV8e is starting off with a positive reputation.
Minneapolis, Minnesota. The buckle on the rust belt.
They preemptively salt the streets when snow is predicted. My F3 will soon be in storage 'til April. I consider it project season; April thru October is driving season.
  #157
Old 10-28-2005, 03:38 PM
29abone
29abone is offline
29abone is starting off with a positive reputation.
Red face Location
Located in Taylor, MI 3 miles east of Detroit airport.
Larry
  #158
Old 10-28-2005, 09:44 PM
novatattoo's Avatar
novatattoo
novatattoo is offline
novatattoo is gaining momentum as a positive member of FTE.
Canton,Ohio. Pro Football Hall of Fame city. About an hour south of Cleveland,OH.
Later,Bill
  #159
Old 10-28-2005, 11:43 PM
rysam
rysam is offline
rysam is starting off with a positive reputation.
50 f1 in paradise ca. 2 hrs or so north of sacramento
josh
  #160
Old 10-29-2005, 07:47 AM
learpilot
learpilot is offline
learpilot is starting off with a positive reputation.
Cool! Fly for one of the teams? I'm a transplant [email protected] MS '78. Been here since 79, call it home. Married one of the few BORN & BRED CH girls.
AXracer, I have done some part time for Gibbs, but now I fly corporate. Have a son living in Raleigh.
  #161
Old 10-29-2005, 01:59 PM
rog300b
rog300b is offline
rog300b is starting off with a positive reputation.
I am located in Narvik, nothern Norway, not far away from Mats in Kiruna.
Roger.
  #162
Old 10-29-2005, 05:03 PM
old fool
old fool is offline
old fool is starting off with a positive reputation.
Where are we?
I thought there would be more of us in the Southeast.
  #163
Old 11-02-2005, 09:18 PM
SgtCrump
SgtCrump is offline
SgtCrump is starting off with a positive reputation.
We are in Las Vegas, NV
  #164
Old 11-02-2005, 10:50 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Please post on the map
  #165
Old 11-03-2005, 03:21 AM
SgtCrump
SgtCrump is offline
I did.....I'm the only one there.
Quick Reply: Where Are You?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
