1978 - 1996 Big Bronco
smokin bad
Old Oct 18, 2005 | 02:53 PM
Dj300ford's Avatar
Dj300ford
smokin bad
Today i drove around 15 minutes and seen my bronco was smoking everywhere so i took it to the back of the driveway, smoking comming from under the hood at back of engine and blue smoke out exhaust and rear of engine covered in oil. Should i look in to the problem or replace the engine? and what could of happened
Old Oct 18, 2005 | 02:57 PM
IndySilverAnny's Avatar
IndySilverAnny
I'd look into it before tearing out the engine... Could just be a loose oil filter, broken dipstick tube, or, if it is coming out the exhaust, bad valve seals.
Go thru the process of elimination first.
Look for major oil leaks, gaskets that have pushed out, loose drain plug, dipstick blown out, PCV valve and hose rotted or broken, etc.
Good luck, and post an update with any findings.
naiku
Jan 21, 2016 11:31 AM
jmtbiggin
Jun 2, 2015 11:25 AM
85Supclub
May 6, 2015 06:00 AM
dieselgirl808
Apr 17, 2013 12:05 AM
dtony
Apr 28, 2003 02:29 PM
