Going to change my lower rad hose any tips
If the weather is nice I'am going to change the lower rad hose on my truck before it desides to blow at the worst moment. The Gates rad hose I got has no spring so do I have to take the spring out of the other hose or can I run with out. I can't see that hose sucking flat with the fill hose piece in the center. If I do I guess I will have to wrestle the spring into the new hose.
I did buy screw type all stainless clamps to replace those spring clamps Ford uses I think it should be okay to use the screw (worm drive) clamps.
I bought 4 US gallons of antifreeze plus I got a bottle of additive I don't know if I pick up enough antifreeze. The antifreeze that is in the rad now isn't very old because there has been engine work done so the thermostat has been changed etc.
With no rad cap on the radiator I assume every thing has to be filled throught the bottle on the fender.
Any other things I should do ?
