Would this fit 35s on a 93?
I've seen a 79 Bronco with a 3" body lift clear 35s with no rubbing, and it shouldn't be to much different for a 93 and you would have a 4" total lift and if you had proper backspacing on your rims you might be able to clear those 35s without rubbing too.
BUT, going with a 4" lift would be a choice, b/c it wouldn't cost much more, and would clear 35s with no problem.
A 93 is gonna need the body lift and +4" of suspension to clear 35's cleanly (without rub at steering lock). 78-79's were totally different body style and cleared larger tires right off the showroom floor than later models. Personally, I'd do away with the body lift entirely and just run 6" of suspension lift. Its more expensive but you gain a lot more articulation (suspension flex) and it looks cleaner.
Remember to regear for 35's or your mileage and performance will suffer dramatically.
Originally Posted by DARK_HORSE
I also cut 2" off the front bumper.
Even if your 35's fit with 2.5 inch more lift you will have very little wheel travel. Would not be a bly to flex. With my truck I am running 6 inch lift with 33's. It doesnt look bad and I have tons of wheel travel. Trust me it is better to have smaller tires and more wheel travel than to have bigger tires with no wheel travel....
Some people are just way too obsessed with look. And that's apply to many facets of today's life, not just how much better a bigger tire looks on the Bronco.
If it occasionally rubs on the radius arms that that's not too bad, but the bumper can slice it open in a split second if you happen to have a hard landing with the tires turned to the "right" direction.
