1978 - 1996 Big Bronco
86 bronco engine swap
Old 10-15-2005, 11:22 AM
rbuys
rbuys is offline
rbuys is starting off with a positive reputation.
Exclamation 86 bronco engine swap
I have a 351 modified and want to put a 5.0 EFI in how much trouble will i have
Old 10-15-2005, 01:08 PM
IB Tim's Avatar
IB Tim
IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 10-15-2005, 08:34 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
351 Modifieds weren't avalible in 86, the only351 in 86 was the 351W.
Depends on what was currentally behind the 302, manuel or auto?
If for some reason it is a 351M then you would prolly need new motor mounts too.
Double check which engine is in it, and then some more people will be able to help out.
Old 10-16-2005, 01:12 PM
rbuys
rbuys is offline
Sorry it was a 5.8L with a carburator I have a 5.0L EFI out of a crown vic i know I'll need different mounts. Curious about the electronics?
Old 10-16-2005, 01:43 PM
aurgathor
aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
You need matching computer, wiring, and sensors.
Old 10-16-2005, 02:38 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
the crown vic motor would not be a good choice. its setup for a car not a truck . the 5.8 is a far better choice
Old 10-17-2005, 01:18 AM
johnboy427's Avatar
johnboy427
johnboy427 is offline
johnboy427 is starting off with a positive reputation.
Your 302 will bolt right in with 351W mounths and bellhousing. 289 (1965 and up), 302s, and 351C/W all have the same motor mounts the modifieds (351/400) have the same mount as the 385 series big blocks even thought they are 335 series small blocks. thats about all i can tell you the wiring is going to suck for minimal performance gains mabey put a carb on your 302, if you had a Mass air motor out of a mustang for something it would be worth it but those speed density crown vic motors are mostly dogs. If you find an 1989 or new cop car you can get the good motor and easy way to tell if if the throttle body is on the drivers side of the intake you got a dog if its on the passenger side you got lucky
-johnboy
Old 11-10-2005, 04:39 PM
rbuys
rbuys is offline
Thanks to everybody that answered my questions
trepid94
09-18-2016 11:48 AM
allenolsen
18
06-19-2015 06:41 PM
kevin316
05-27-2013 11:18 AM
blue88EB
07-23-2007 04:50 PM
krazdndenver
09-21-2002 07:06 AM
Quick Reply: 86 bronco engine swap
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
