1978 - 1996 Big Bronco
Best brakes pads.
Old 10-10-2005, 07:17 PM
azjan
azjan is offline
azjan is starting off with a positive reputation.
Best brakes pads.
What brake pads do you prefer?
Old 10-10-2005, 07:49 PM
MatthewC's Avatar
MatthewC
MatthewC is offline
MatthewC is starting off with a positive reputation.
The cheapest ones I can find. Dont care if they dont last as long that the best ones, it only takes a few minutes to swap them out.
-Matt
Old 10-10-2005, 08:49 PM
BroncoRoadKill's Avatar
BroncoRoadKill
BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
I like the autozone lifetime warrenty one, you wear them out, take them in they give you another set.
Old 10-11-2005, 01:45 AM
93BigBlackBronco
93BigBlackBronco is offline
93BigBlackBronco is starting off with a positive reputation.
I like the mid grade stuff. Quit buying lifetime when I realized they wear out and warp rotors. They work too good too much heat.
Old 10-11-2005, 04:48 AM
aurgathor
aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Brake pads are much cheaper than rotors, and are a lot easier to replace, too.
Old 10-11-2005, 04:06 PM
dhepler's Avatar
dhepler
dhepler is offline
dhepler is starting off with a positive reputation.
carbon metalic performance friction used to be the way to go. I started with these because the don't eat up your rotor and they work great plus they had a lifetime warranty from AZ. Now they don't carry a lifetime but I still get it, so when they wear I don't turn the rotors and just change pads at no expense. I am very happy with them
Old 10-11-2005, 11:00 PM
azjan
azjan is offline
Smile
Save the rotors. Got it. Thanks all.
Old 10-12-2005, 09:29 PM
Hamfisted's Avatar
Hamfisted
Hamfisted is online now
Hamfisted is gaining momentum as a positive member of FTE.
Akebono ceramics....
I've tried a bunch of 'em and the best I've used to date are the Akebono ProAct's ceramic pads from Tire Rack Online . They stop well, even towing a boat, and they don't blacken the front rims with brake dust. They haven't worn the rotors any worse than anything else I've used. Hell, get some new slotted rotors if you want to. The Broncos just go through front brakes a lot, I still got the original rear shoes on there.
Mike
'96 5.8L EB
Old 10-14-2005, 11:10 PM
azjan
azjan is offline
Cool Rotors
OK. What rotors do you guys prefer. Seems like any pad, rotor combination I try only lasts 8, 9000 miles before it starts to shake a bit stopping from 60, 65. Bearings are snug. I guess thats the way it is now days.
Old 10-14-2005, 11:27 PM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Amazing. Use the cheapest pads you find, and then complain that your brakes only last 8000 miles.
Whatever happened to you get what you pay for?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
