At one point in time i had a ebpv
on
1 Post
I know for a fact my psd has a ebpv. i have heard it. but i havent heard it runing in almost 2 years. i could hear it from the tail pipe but i cant now. I will tell you that i had a turbo put on the truck shortly after i bought it. could it still be unplugged some how? the truck will go to high idle but i havent heard the valve working in a long time. i even tried to push the rod over at high idle once to see if it was stuck. any sugestions on what i should do to get it working again? or to check if it is working? should it cycle at start up regardless of temps?
on
1 Post
Originally Posted by HeatStroked
Open that exhaust up and gut the valve. Not really needed unless you want to make a brake out of it or you live in very cold weather state.
on
1 Post
I see. Well, I suppose the backpressure solenoid could have failed. Can you get your DTC's read? If it isn't working there should be a P0475 or P0476 code stored in your PCM.
Added on edit: If the PCM detects an exhaust back pressure or intake air temperature sensor fault it will disable the exhaust back pressure device.
on
1 Post
so what do you think about the ebpv kwik?
Should it cycle at start up?
How would i check to see if the solenoid is working? i was thinking something along the lines of a circut tester. but where do i test.
forgive the 20 questions...i just dont know what i am doing when it comes to the psd. i had a dodge with the cummins and i knew that motor inside and out.
Originally Posted by guthrie&co
so what do you thik about the ebpv kwik?
