Sponsored by: Real Truck
Hello guys-Need info
Old Oct 6, 2005 | 04:05 PM
Vijay's Avatar
Vijay
Hey guys,
I'm planning on buying a pre-owned 2002 V10 pick up truck (Crew cab, 8feet bed). I need this information...
1) What is the average gas mileage of 6.8L V10 in City/HW?
2) If I have to install 38" tires (max allowed in NJ) what is the minimum lift I need? How much would it cost for basic lift and really good tires?
I have no intensions of using it for off-Roading. As a matter of fact, I have nothing to haul either. I’m a software Engineer and part of the reason why I came to USA is because of big FORD SD’s and Harley’s. JUST AWESOME trucks and bikes! This is truly living large!
Thanks,
VJ<O</O
Old Oct 6, 2005 | 05:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Moved and member notified
Old Oct 6, 2005 | 08:26 PM
dmp437's Avatar
dmp437
1.) Mileage: Doesn't matter. If you're putting 38's on it you're not concerned about mileage. If you go with something more modest, expect 12.5 mpg.2.) Cost: If you're set on 38's add the cost of gears into the equation. Plan on $2000 for gears. Check the label inside the driver's door under the "axle" section to see which gears are in it now. If you have 4.30's you can go with 33's and still have it remain "normal" as far as driving ability. Bigger tires, either 33's or 38's, will need wider rims than the stock 7" rims. At least 8" and maybe 10".
So if I'm thinking straight (I'm tired); $1500 for the lift, $2000 for the gears, $800 for the rims, $1100 for the tires which comes to $5400. Then figure a few extra hundred for fresh plugs, belt, transmission service, front end alignment after the lift.
Post a few pictures after you get it
