02 oil leak
Old 10-05-2005, 10:55 PM
GigAg04's Avatar
GigAg04
GigAg04 is offline
02 oil leak
Truck is 2002 PSD, 4x4 crew cab. 109k miles.
Saw some oil spots on the ground so I grabbed the creeper and took a look underneath. Oil pan has oil/dirt residue on it. Also, there are two metal tubes (1/4" dia. maybe?) towards the passenger side of the oil pan - one of these had oil beaded up and was where the oil was falling from.
I assume the oil is leaking somewhere else and running down the silver tubes to the lowest point and then falling into a puddle. Any ideas as to what this might be?
Truck is only 3 weeks old (to me) so I want to take it back to the dealer but I'm not sure how far this will get me.
Thanks,
-nick
Old 10-06-2005, 06:05 AM
bilder12's Avatar
bilder12
bilder12 is offline
I would go to the top of the engine ... seems there is a better chance of finding the leak up there in the valley pan. pedastal or turbo o rings or hpop oil line leaking. if it is lower, look at the cam position sensor o ring on the front of the cover (the timing indicator is the cam position sensor ) which has an o ring seal. hope this helps.
Old 10-06-2005, 06:57 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Sounds like the flange for the dipstick tube is leaking.
