2001 Ford F250 Super Duty Diesel will not start
I just purchased this truck from my Uncle. I had a 99 with no problems. The other day I started up it stayed on for a second and turned off. It did this gain on me and I noticed the oil pressure was very slow like more than 5 seconds to come up. I was going to take it in to see the problem today and it would not start at all. Any suggestions
Two possibilities come to mind right away. First, does the tach move while cranking? If not, possible CPS. Second, battries not fully charged can spin the starter, but have enough umph to start the truck. Many folks on here have had that issue lately. Eveyone thinks it can't be battries because it spins well. Check the voltage at the battery while someone cranks the starter. Should stay above 11.5 volts. I am sure others will chime in with other possibilities, be patient.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
cubinzkid
12-16-2014 12:06 AM
dcara
11-07-2013 01:46 PM
brcwelding
02-06-2012 09:16 PM
mtgrzlyman
1999 to 2016 Super Duty
01-07-2011 04:27 PM
