Would like to unhook all buzzers on my 86 F-250 460 4spd. the door buzzer sounds like it's under the right side of the dash, does anyone know the location of these retarded things and can I just unplug them ? any and all help would be greatly appreciated. thanks.
Great, thanks Piffery1. that should take care of the door buzzer, I want to unhook the other buzzer as well for the ignition switch, as soon as I can locate it, I'll probably take the whole top dashboard off cause it needs a good cleaning anyway, but I'm hoping I can just unplug the buzzers without a problem.
It's just one buzzer. Once you unplug it, everything is gone.
Take a look at the top of your glovbox, you'll notice a cutout in it just behind the latch, reach up through there, the buzzer is a bit to the drivers side. Should be the only thing there, unplug it and all is well.
I pulled the dash off today and unplugged the buzzer, I was amazed to see how many wires ran to this thing, I think it's 3 or 4 buzzers in one cause it makes a different tone for the door than the ignition, when I turned the ignition on I noticed I've lost all the warning lights in the dash, no big deal but I have to check if I still have my oil pressure light, it could be burnt out cause I don't think it's wired into the buzzer. we'll see tomorro. thanks again man.
