Kill Switch
Old Sep 24, 2005 | 09:12 AM
TheRoadVirus's Avatar
TheRoadVirus
Kill Switch
Is it possible to install a kill switch on a 1990 F150? How would I go about doing it?
Old Sep 24, 2005 | 03:45 PM
Franklin2's Avatar
Franklin2
Do you want it to crank and not start? Or not crank either?
If you want it not to crank, then you can interrupt the red/lightblue wire. You will find this wire out at the starter relay on the passenger side fender, and you will also find it on the clutch pedal if you have a manual tranny, or on the driver's side part of the tranny for an automatic.
If you want it to crank but not start, you can interrupt the tan/lightgreen wire going to the fuel pump relay. You should have a bank of relays under the hood, and one of them is the fuel pump relay. The computer uses the tan/lightgreen to fire up the fuel pump.
Skorpion007
Jun 15, 2020 10:01 AM
joe blow
Apr 2, 2017 11:22 PM
joshua6430
May 31, 2015 08:47 PM
curt9999
Feb 19, 2009 01:00 PM
pdaddy
Jul 7, 2008 08:37 AM
