I'm smelling gas in my cab after and during hard acceleration. I thought it was maybe loose gas cal or something but last night when I got home I could smell it strong when I walked around to the front of the truck. Could the injectors be leaking? Is there a effective way to test the system at idle in the driveway?
check your oil right away. if it smells like gas you have a bad fuel pressure regulator. it would need to be changed right away and your oil drained before its driven further otherwise the gas will wash the bearings an you will need a rebuild
i have the same year rig , i guess it could be possible but you would see evidence of it happening when you look around them especially after driving around. thats why i think the fpr is more of the issue.
If the fuel pressure regulator is bad, there is gas going in the oil?? Also if so would u be using more oil that was like buring oil?. Thats happing to be. I smell gas and Im using oil. 1983 302 carb
the regulator if it fails causes lots of extra fuel to be dumped into the motor. the gas drains down past the rings and into the pan. if you run the motor or even turn it over enough times the gas will wash the bearings and eat gaskets. its really bad.
