Please HELP F250 powerstroke dead on side of road!!!!!
From underneath is the only way to reach it. Pop the 10mm bolt out (I leave the belt in place and use a small extension on the socket), then use a small flathead screwdriver to pry the sensor loose. Mid afternoon on the side of the road it takes 10 minutes....probably a few minutes longer at night, and way longer without a flashlight.
How much is the ICP job going to cost?
Originally Posted by jesus_man
Sounds like you're having similar trouble as mine, but I had no warning. Mine just died 2.5hrs from home and the dealer is replacing the ICP today (after I replaced the CPS), so I will let you know, or you could read my thread "My 2002 PSD Died". I hope you get it figured it.
J.D.
J.D.
Because I have seen it, and have worked after it's happened...please make sure you have a road spotter with you with a flashlight and or a flare...or better yet..have a vehicle or few behind your rig to ensure should someone come along with their head up their six they plow into something other than your rig.
longhorns13
13
11-09-2010 09:44 PM
mrlightrail
08-25-2007 09:41 PM
