Offroad & 4x4
f650 as a monster truck
  #31
Old 09-21-2005, 07:44 PM
RawPower's Avatar
RawPower
RawPower is offline
Some BS posts:
Twin turbo stuff, funnier the lower you read:
https://www.ford-trucks.com/forums/s...d.php?t=386583
Plans on buying a 350 as well as the 650:
https://www.ford-trucks.com/forums/s...d.php?t=370934
For turbos with remote oil resevoirs:
https://www.ford-trucks.com/forums/s...64#post2606364
A little help (not really, cause hes wrong) on brake trouble:
https://www.ford-trucks.com/forums/s...d.php?t=351453
Cool, I guess:
https://www.ford-trucks.com/forums/s...62#post2366562
And I got bored... they are better at the top.
  #32
Old 09-21-2005, 08:18 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
Originally Posted by falcor1
as for this topic,all i'm asking for is some tips for making a f650 into a 4x4 feild truck.now i have been offered some engine packages to chose from.some of them include a 498 c.i. engine,a 540c.i. engine,a caterpillar 11.1 liter engine and a inline 6 cylinder by cummins,although i have to get some information on the last 2 engines.now i'm looking into getting some tires and axles,ones that will work for some fields that will most likely get soft and muddy.anyways i saw some trucks that LOOKED like they were well done.they most likely are good trucks.i would like to discuss the features of these vehicles with the guys that own them and maybe use some of their ideas on the truck i'm working on.
the hell could you ever want to do with an F650? it would SUCK horribly offroad. the springs would be stiff as I-beams, the weight would be too much, and the size is too cumbersome. you already have the axles and tranny and t-case to handle the rigors of offroading but there is no practicallity in the idea.
my only 2 suggestions to you regarding the original topic of this really not offroad related thread. WELD the front and rear diffs. free lockers. second... dont get a gas burner.... go with some oil burner, either a CAT or a cummins or International but domething that big built to handle crazy loads needs the torque of an oil burner. plus you can run stacks
-cutts-
  #33
Old 09-21-2005, 09:26 PM
Chris_ce's Avatar
Chris_ce
Chris_ce is offline
Wow That whole thread is messed up.
Stick a 650 in a wet farm field and watch it sink.
  #34
Old 09-21-2005, 09:38 PM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Exactly. Never mind trying to drag a trailer behind it.
I just want to see pics. That's all I want, just to see some pics of this. What I really want to see is the pic of this thing on it's side when he tries to pick up a 2K lb+ bale that is off to the side of this thing. Then, then I will LMAO!
  #35
Old 09-21-2005, 10:30 PM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Okay, I don't know why I'm interested in this. I guess it's just what amuses a simple mind. I had to look at the public profile and this guy is a modern day Picaso. I mean come on; with these qualifications this guy's intelligence is so far beyond what any one of us here would understand, it's no wonder we are confused and don't understand his concepts. NASA called me last night and asked if they could have their lead "in-flight missle repairman" back.
Biography: cook,mechanic,r&d researcher
  #36
Old 09-21-2005, 11:03 PM
shockwave6's Avatar
shockwave6
shockwave6 is offline
Is this what your thinking about? Hope this helps
https://www.ford-trucks.com/user_gal...oid=89836&.jpg
  #37
Old 09-21-2005, 11:41 PM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Yeah almost, but I wanted to see outriggers too. I'm really interested in the list of mods to make this thing functional and the final cost.
And the bales are too small. Just one of those is bigger than the bed.
  #38
Old 09-22-2005, 12:00 AM
ivanribic's Avatar
ivanribic
ivanribic is offline
You forgot the crane. How could you forget the crane? I still say it needs more cow bell.
  #39
Old 09-22-2005, 12:04 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Gotta have the thrasher on the front and a 3 point on the back too. That would be the pimpinest vehicle on the farm.
  #40
Old 09-22-2005, 12:22 AM
shockwave6's Avatar
shockwave6
The crane is there it just blends a little! It is where the tool box normally is to balance the load.
https://www.ford-trucks.com/user_gal...oid=89847&.jpg
https://www.ford-trucks.com/user_gal...oid=89848&.jpg
  #41
Old 09-22-2005, 01:30 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Shock, yer just wrong in the head! LMFAO!
  #42
Old 09-22-2005, 02:05 AM
76fordtruck's Avatar
76fordtruck
76fordtruck is offline
maybe this is what he is trying for... THE BEST OF ALL WORLDS!
you can pull 100 bales, wheel over two trucks and look totally xtr3me while doin it! https://www.ford-trucks.com/user_gal...=89850&width=0
ok....wheelin over other vehicles may be pushin it for this 650 soo i'm thinkin this design is MUCH more practical
https://www.ford-trucks.com/user_gal...=89851&width=0
big ole meats go through muddy fields like nuthin!
  #43
Old 09-22-2005, 10:25 AM
featherbrain's Avatar
featherbrain
featherbrain is offline
boy this guys a dunce.i've seen a f350 with a 20 something foot trailer and tractor do better than anything than anything bigger.i hope he does something.i know when you put a truck in a soft feild it has to have a lighter weight and the powertrain to pull itself out when loaded.my only suggestion is that if he sticks with truck he gets something like a detriot 466 to run in it with maybe a allison 6 speed tranny.
  #44
Old 09-22-2005, 10:26 AM
warrencowboy05's Avatar
warrencowboy05
warrencowboy05 is offline
LMFAO! you all are freakin hillarious! and notice that this guy hasnt writen anything back!
adam
  #45
Old 09-22-2005, 01:37 PM
proeliator's Avatar
proeliator
proeliator is offline
This is the best thread I've seen in awhile, instant classic!
Quick Reply: f650 as a monster truck
