linclon manfolds on a ford y block??
Is it possible ot put the LInclon manfolds on a ford y block? I have access to a set of linclon rams horns and a couple of welders that have no problem with cast welding. is the only difference the outer exhast ports or are they completly different? thanks
No, it won't work. Check this out:
http://www.m571.com/yblock/exhaust.htm
Not only don't the mounting holes match, but the Lincoln is a longer motor (greater bore spacing between cylinder center lines) so the end ports are farther apart than they are on the Y.
