How much does a flathead six weigh
Old 09-11-2005, 04:58 PM
EDMCCLOUGHLOCH's Avatar
EDMCCLOUGHLOCH
EDMCCLOUGHLOCH is offline
I need to buy a cherry picker to pull my flathead six and manual tranny..about how much does this combination weigh....just wondering if the 2 ton cherry picker will be enough.
Old 09-12-2005, 08:29 PM
mtflat's Avatar
mtflat
mtflat is offline
I don't know what a 6 weighs, but I sling my late model flat V8 and HD 3 spd tranny around on a 2 ton cherry picker. The engine alone weighs 569# Your six should be lighter than that. Only caution is to make sure your lift has 4 feet/rollers (not 3) for weight distribution so it doesn't want to go over sideways.
Old 09-12-2005, 10:40 PM
oscarxyz's Avatar
oscarxyz
oscarxyz is offline
I've been told by a few folks that a flat 6 and the rest of the 48-50 pickup weigh in just over 3000 pounds. (for what it is worth).
Old 09-12-2005, 11:51 PM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
A 2 ton hoist is more than adequete for pulling the engine. I have pulled my flathead 6 and trans with a 2 ton hoist with no problems. Same hoist has been used for multiple engine swaps in a few of our projects.
Old 09-21-2005, 04:55 PM
Christopher2's Avatar
Christopher2
Christopher2 is offline
Remember to look at where it is rated as two tons. Some units are rated as 2 tones with the arm fully retracted and go down as the arm is extended. If the motor and tranny are half the weight of the truck it would be a ton or less.
Old 09-22-2005, 09:27 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
A chain is only as strong as it's weakest link.
jetrinka
03-03-2016 07:39 AM
gottahaveaford
15
02-19-2011 12:26 AM
marty68
05-24-2006 01:02 PM
Hellbore
15
05-16-2006 11:07 AM
ADSf100
04-11-2003 06:17 PM
Quick Reply: How much does a flathead six weigh
