Brakes Squeek in reverse
I have an 03' FX4 Screw and I put new pads and rotors on all 4 corners at 41,000 miles and now with about 45,000 on it when I back out of my driveway the brakes have a squeel to them when applying then releasing the brake(only in revearse) When driving around town no squeeking and they stop great. I don't think I have any problem but I was wondering if there was a linkage or something I could lube for this to stop.
sounds like there is just some brake dust stuck in there. take some brake cleaner and spray the rotors while you turn the hub. (wheels off and jacked up) if that clears it up then that is all it was. If it comes back after another 4 or 5 thousand miles then they are not very good brakes.
Lance
Lance
