there is a oem parts suplier called LMC truck that you may want to check into they sent me a free catalog and i think the only part of my 84 i couldnt find was the bezel around the radio in the center part of the dash. they have everything in there its crazy.
BillyBob that what i was gettin at doin. cause that would look way cooler then stock, but i was wonderin if the computer fed off any of the gauges befor i did it.
Since it is an 80, and if memory serves me right, fuel injection was not used until 85 in the full size bronco and that was with the 302. That is when the puter began being used. BUT...Just to be sure. Locate a wiring diagram. That will tell you if there was one or not. Although I doubt it.
