650 NA horsepower
on
I suppose it can be done, but I don't know how reliable (or streetable) it would be. Is this just theoretical, or do you have a vehicle in mind for this engine? And what would its intended use be?
You'd have to use virtually all aftermarket parts, including the block. A stock block is good to about 500 hp, after that things get a little dicey. Are you talking about an actual displacement of 302 ci, or the basic 302 package but bored and stroked? It would help a bunch to get more cubes in there to start off with. Perhaps a 347 kit would do it.
And why a 302 when you're looking for that kind of power? Why not a 351W stroker? I think you can get up to 427 ci with the 351W.
I'm more partial to the 302 myself, in part because of the smaller physical size and weight and because it's the basic engine configuration that came in my Tiger from the factory (260). It's a PITA to fit a 351W in there, and you don't really want to add any more weight to the front end in those things.
The key to this beast is going to be the heads. It'll need to flow a ton of air through it. There are a bunch of good heads on the market for these engines nowadays, but I'd have to sit down and do a little research to pick out just what I would use. I'm sure some of these guys here could come up with something right off the tops of their heads though.
How about induction? Carb(s) or fuel injection?
There's quite a bit involved with this project, and if it's something you actually want to do the very first thing you'll need is a hefty bank balance, 'cause it ain't gonna be cheap!
on
according to my desktop dyno;
build a 302 with stock displacement,
12:1 compression,
2.02, 1.6" valves
ported stock heads
650 cfm 4 barrel
single plane max flow
large step race headers
245/245 duturation at .050
.450" valves lift
solid roller lifters
aluminum roller rockers 1.7:1 ratio
375bs of torque and 178hp at 2500 rpm
525bs of torque adn 550p at 5500 rpm
482bs of torque and 689p at 7500 rpm
454 torque, 691 hp
351 cu;bic inches
2500; 396 torque, 189 hp
5500; 542 torque, 567 hp
7500; 488 torque, 697 hp
with 2.19, 1.73" valves both with 750 cfm 4 barrel
302;
2500 rpm 372 toruqe, 177 hp
5500 rpm 536 torque, 562 hp
8000 rpm 487 toruqe, 742 hp
351
2500 rpm 384 torque, 183 hp
6000 rpm 559 torque, 639 hp
7500 rpm 522 torque, 746 hp
12:1 compression,
2.02, 1.6" valves
ported stock heads
650 cfm 4 barrel
.450" valves lift
454 torque, 691 hp
351 cu;bic inches
302;
351
12:1 compression,
2.02, 1.6" valves
ported stock heads
650 cfm 4 barrel
.450" valves lift
2.02, 1.6" valves
ported stock heads
650 cfm 4 barrel
.450" valves lift
I'm still going to have to agree with TigerDan. To make 650 hp with a N/A 302 ci, I can't think of any stock parts I would use. Not if the engine would have to run for more then a few seconds anyhow.
