Y- Block Oil Leak
Y- Block Oil Leak
My 1955 239 V8 appears to be leaking oil on the driver's side where the head and block meet. Is at the rear bottom left corner above the oil pump.Motor recently overhauled with new head gaskets. There is an oil galley that runs from the pump through the block and into the valve chamber near the leak.Should't make a diff. Re-torqued the head, still leaks. Don't really want to pull the head until absolutely necessary.
Fred
Fred
if it is the valve cover gaskets...the only way I've gotten them to quit leaking at the back corners is to use a sealer on the gaskets...Pep-Boys used to sell something we referred to as "yellow-snot"! Dont know the real name but it worked real well. Clean all oil and grease from head and valve cover surfaces, put sealer on and lightly seat the covers to the head, let is cure and then snug down. This should keep the gaskets from moving around.
Original covers had a lip on the inside that kept gaskets in place....aftermarkets dont seem to have this.
good luck
good luck
Thanks for the replies. I was sure it was not the valve covers as I never could see any oil there. Had the covers off to re-torque the head bolts and after a drive today there is oil around the rear corner of the cover. Will take it off and put hi-temp silicone sealer around and check it out. Will post the results.
Fred
Fred
pappy19
08-24-2015 01:24 PM
Fox73F100
03-21-2014 03:53 PM
bjmayberry2
15
07-12-2013 09:07 AM
fred_79f250
1997-2006 Expedition & Navigator
11-16-2012 12:05 PM
