Overheating '98 4.0
Old Sep 7, 2005 | 12:28 PM
drewg123's Avatar
drewg123
Cool Overheating '98 4.0
Idle is fine, but driving causes the temperature gage to peg. I slow down and the temperature goes back down. In the past I have had cars do this when the fan clutch goes out, but I don't see a problem with this one. I am going to change the thermostat tonigt to make sure that is not the problem.
Old Sep 7, 2005 | 03:18 PM
therealulysses's Avatar
therealulysses
You know how to replace a thermostat and you are asking how to change a belt? I think I'll go over there now...
Old Sep 8, 2005 | 12:10 PM
drewg123's Avatar
drewg123
Well I'll tell you what. It was easier to replace the thermostat then the belt. The biggest problem was finding an 'O'ring. Had to go to the dealer and pay $15 for it. That was more than I paid for the thermostat.
Old Sep 8, 2005 | 12:31 PM
Gil Chesterton's Avatar
Gil Chesterton
My thermostat came with an o-ring. Lucky I guess.
You didn't say if the engine was ACTUALLY overheating you just state that the guage is pegged to the high end. Check the coolant temperature sending unit and see if it is functioning properly.
I assume if steam is flying out of your rad that you actually have a real issue but it may be a failing sensor.
Just a thought.
Old Sep 8, 2005 | 01:42 PM
drewg123's Avatar
drewg123
Oh, the thermostat fixed it. Needle was pegged and the 'Check Gauge' light was on. The air conditioner didn't work either. I still think it was strange that it cooled down when idling and got hotter when moving.
Old Sep 8, 2005 | 07:33 PM
bulldog3531's Avatar
bulldog3531
While driving your engine is working harder so it will run hotter so when at idle it will cool some since the engine is not working as hard.
