Power Steering Pump Failure
Old Sep 6, 2005 | 08:22 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
I am very surprised my 2001 Expedition has developed a power steering leak as determined by my local Ford Garage. Does anyone know if this is common at 135,000. . I have had Fords last much longer with no PS pump problems at all. You input is appreciated.
Old Sep 6, 2005 | 08:30 PM
ford390gashog's Avatar
ford390gashog
wheres the leak? the gaskets in these new units can shrink when the seal swell additves are gone. when was the last time it was serviced.
Old Sep 6, 2005 | 09:15 PM
NorthCarolinaExpy
Hi and thanks for the reply. . .the mechanic at the Ford Garage did not specify a location for the leak in the power steering pump. . but I can see fluid has been sprayed upward to the engine. . according to the mechanic, the power steering pump is leaking and needs to be replaced. . . $375 labor and parts. .
I noticed a small drip at the hose connection at the bottom which prompted my visit to the garage for further investigation.
Old Sep 6, 2005 | 09:39 PM
orleec's Avatar
orleec
Wow, $375 is 100+ gallons of gas (no pun intended).
I just flush my wife's V70 steering using Mobil 1 ATF since it was never done in 8 years, and now it's all pink.
I might do the same for our XP before winter comes, hopefully a preventive maintenance...
Is Ford power steering the thing to use? I read about a member that used Royal Purple Synth that somehow made the operation quiter (Lord knows how noisy the power steering of 1st Gen XP is). And what of this additive? Is it a Ford product?
Any tip on power steering flush will be appreciated.
Thanks
Old Sep 6, 2005 | 09:40 PM
ford390gashog
375.00 what crooks. absolute crooks
Old Sep 6, 2005 | 09:41 PM
ford390gashog
Thanks
nope they just use tranny fluid
Old Sep 6, 2005 | 09:44 PM
ford390gashog
a rebuilt power steering pump is only 65.00 . the tank and the pump are seperate.
Old Sep 6, 2005 | 10:02 PM
orleec's Avatar
orleec
Better put it on my list of things to do, the fluid on mine is all dark. I checked and it does require Mercon ATF, so I will use Mobil 1 ATF.
Old Oct 27, 2005 | 01:25 PM
wyo_vr4's Avatar
wyo_vr4
That's a bargain compared to the $520 I was quoted today at the stealership... How hard is replacing the power steering pump myself? I have a '99 Navigator.
Old Oct 27, 2005 | 04:18 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome wyo_vr4, to Ford Truck Enthusiasts!
…..See you on the boards.
