3rd Brake Light for 2003 F150
Hello,
I recently purchased a 3rd brake light for my 2003 F150 supercab. It is the same brake light as the Lighting truck. It said simple to install and no modifications needed but when I pulled the old light out I couldn't find the end with the connector. Is it located inside the truck somewhere? Does someone have a wiring diagram for this? I had to put the factory one back in since I couldn't disconnect it. Thanks for the help.
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Hello,
I am having the same problem with mine right now. Were you able to do it easily at all? Could you possibly tell me how you accomplished it? Thanks!
jbanta1983
1999 to 2016 Super Duty
02-21-2016 08:02 AM
