O/D Off Light is flashing
Old Sep 3, 2005 | 11:46 AM
tcatt's Avatar
tcatt
1997 Explorer 2WD, 193000 miles....O/D off flashes, It does not do it all the time it is very intermitted.
I had a local mechanic read the code and he said it could be a number of things.
I am putting in a new motor.....Should I change the torque converter and pump while the engine is out....thinking that any other problem would not require the trans to be pulled?
Suggestions appreciated.
Old Sep 3, 2005 | 05:24 PM
AlfredB1979's Avatar
AlfredB1979
How about get the code numbers and then deicide from there?
PROPER diagnosis can save you money here. Bad guesses won't.
