Anyone Using A Summit Camshaft
Old Sep 1, 2005 | 02:52 PM
turbocoupe5.0's Avatar
turbocoupe5.0
I'm in the middle of rebuilding the 460 in my 87 F250 4x4. I use the truck as a daily driver (winters mostly) and I occasionally haul a truck camper (about 2000 pounds). It's has a ZF 5 speed, 4.10 gears, & 33" tires. The rebuild is basically stock. Re-ring, new bearings, lap the valves, new oil pump, gaskets, seals, etc. I'm putting the stock 4180 holley on a Edelbrock Performer intake. My question is about the cam. I'm thinking about using a Summit cam kit PN:SUM-K3500. It's 204/214 duration at 0.050" with 0.479"/0.504" lift & 112 lobe seperation. First, has anyone used this cam / cam kit with stock bolt down rockers, pushrods, etc? Will I need to get custom length pushrods? The block and heads have NOT been milled and I will be using a stock thickness head gasket. Second, I think this is the right size cam for the job. I don't want to over do it. I know the stock cam is absolutely pathetic at best. Does anyone have experience with Summit cams? Would I be better off spending another $60 for a crane/comp/edelbrock cam kit? Anyone know if Summit is just buying these from a major cam manufacturer?
Old Sep 2, 2005 | 05:53 PM
kermmydog's Avatar
kermmydog
I have never used a Summit cam kit, I can say that I plan to use a Lunati Cam with .535/.540 lift and plan to use stock length pushrods, After talking with a buddy of mine he told me to go with a chromemoly pushrod, he said he has had trouble mushrooming the ends of stock pushrods. I'm sure if you call Summit they will tell you who builds there cam kits.
RSpaeth
Jan 20, 2016 10:12 AM
JustinP
27
Jul 16, 2015 07:44 PM
HVACTOM
Mar 13, 2015 09:34 AM
351Cleveland C4
21
May 12, 2014 03:49 PM
Jayman1976
Jul 26, 2013 06:41 PM
