A challenge: 20 mpg in a 460/429
#76
#77
#79
There is an article somewhere on FTE that decodes the plates but I can not find it. I need a day off so that I can sleep and recharge myself. Next week I am not going hunting. Sleep first, Bambi latter.
#81
KRDiesel
I want to clarify that what I should have said is that this "sweetspot" was often true in 4X2 pickups. Motorhomes are another game entirely.
With all the added weight that I know you are carrying and no doubt additional wind drag a change to 3.08's might not give you enough oomph with the additional drag. The 3.55's might even be a little high speed for an RV I changed over to 4.10 for handling my camper.
#86
460 20 mpg
just a thought...but the outputs are not that much as to cause an explosion...as soon as the gasses hit the air they dissipate very quickly.Most engines are running on the rich side as the fuel is not entirelyl being burned..this is why the HHO helps...it allows the fuel to burn more completely cooler ,cleaner...thus more efficient..
tough quest to make a big volume engine drink less..good luck
#87
for HHO to work as intended you have to trick you car into running richer than normal. If you end up breaking a feed line you will be running your engine at a very rich setting and that will burn your motor.
I did not mention explosion in my thread as that was not what I was talking about.
#88
if a 2.0 litre motor gets 45mpg, and a 4.0 litre motor gets 23mpg(if your lucky) then a 7.5 litre motor(aka460) would do well to get 13 to 15mph.its just a big air pump,with more air you need more fuel,no way around it(14.7 to 1)you may lean it out but you ruin your ability to make power and if you dont need the power put in a smaller more fuel efficient motor.i get 12mpg in mine in a 5400lb truck 38' tires with headers and dual exhaust,stock carb, cam and compression.makes lots of power but not very fuel efficient.
