Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Newbie "Power" Question - 2002 HD F150
Old 08-29-2005, 10:29 PM
steinjr's Avatar
steinjr
steinjr is offline
I just picked up a 2002 HD F150 w/ Supercharger. It has 60k miles... The truck seems to have a very quick engine response when it is moving, but from a dead stop it won't spin the tires when I floor it. Is this normal? It does take off quickly... Is there some sort of anti-slip rear end or do I have a problem? My older F150 with a 4.6 spun the tires accidentally all the time...
Old 08-30-2005, 06:30 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-30-2005, 10:29 AM
haystacker's Avatar
haystacker
haystacker is offline
I have a 2002 H. D. with the 03 lighting upper pully, S.S. full lengh headers, preadetor chip. It also does not spin the rear tires from a stop. These trucks have limited slip Diff.
Old 08-30-2005, 05:45 PM
stevef100s's Avatar
stevef100s
stevef100s is offline
Must be the wheel base and extra weight. I've had a 99 Lightning, and now a 03. Both SMOKE the tires from a dead stop.
Old 09-01-2005, 07:14 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Depends,
I found the lightning to be easily able to melt the tires...
I've never driven a HD, but with sticky rubber, a tight limited slip rear end, and good pavement, I could see it not spinning off the line. If you stabbed the throttle vs smoothly going to WOT, you'd have more of a chance.
The lightning's auto tranny is setup a little stiffer, so more abrupt power is sent to the rear wheels. The HD is a little smoother, so that power transfer is going to be softer/smoother, making it "difficult" to spin the rear tires.
Copedawg
17
04-24-2011 07:43 AM
Vaccuum
11-18-2010 11:54 PM
mobriensnow
1999 to 2016 Super Duty
16
08-01-2010 04:06 PM
electrk
07-31-2007 09:07 PM
Quick Reply: Newbie "Power" Question - 2002 HD F150
