Droning Noise PSD 6.0 2005
Hey guys,
I have an Excursion 6.0 PSD 2005 and it has about 7000 miles on it. Between 1250 and 1950 RPM there is a drone noise which really peaks at 1600 RPM. Dealer says it is normal. So,....I'm checking if it is or if my dealer gives me the run around.
Do have the same noise at these RPM's?
Thanks for your help guys,
Ray
Ray
Under load at 1500 RPM, I get what might be a similar noise
At 1500, I get a noise which may be the same as yours. Go to this thread and check the video link there. If it's the same noise, I haven't found a solution but apparently there is a computer flash which changes the transmission shifting strategy so ineffect this noise is masked.
Larry
https://www.ford-trucks.com/forums/s...rbo+vane+noise
Larry
