Sponsored by: Auxito
intermittent high voltage....not alternator?
Old Aug 28, 2005 | 05:33 PM
willy2005's Avatar
willy2005
Question intermittent high voltage....not alternator?
On my drive home from work yesterday I noticed my battery light on & the voltage guage pegged high. Came to a stop light, voltage returned to normal, light went out. At first acceleration, light on & high voltage. I turned on everything I could (headlights, AC, etc) & this held voltage normal until I got to the Sears garage who tested the battery. Battery good & something is overcharging....probably alternator but he couldnt test it. I made it home & decided to remove the alternator & take it in for a bench test. Tested good at both Autozone & Pep Boys. Got home, cleaned & tightened all connections & problem did not reappear until this afternoon. Same thing.
I've never seen a high voltage fault before. I'm also confused with the intermintent times it happens. Only when I get RPM's near 2000 & there is no load elsewhere. This is a stock XL without all kinds of electrical options.
Any and all advice is appreciated.
2003 Ford F-150 XL
4.2 6-cyl, manual transmission
48000 miles
-Bill
Old Aug 28, 2005 | 07:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Bill, to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 28, 2005 | 08:58 PM
steve(ill)'s Avatar
steve(ill)
the only way to get overcharge is for the alternator (voltage regulator) to think the batery is dead. either you have a bad wire or conection on the alternator terminals, or the voltage regulator is on the blink. if the terminals are all clean and look good, how old is the alternator?? bet on that.
