Kill Switch
Old Aug 27, 2005 | 11:07 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Kill Switch
Hey Guys
I Was Thinking Of Installing A Theft Deterrant Kill Switch.
What Do You Guys Think About Splicing Into The Fuel Pump Cut-out Wiring. The Wiring In The Kick Panel On The Passenger Side.there Is A Cut-out Switch Located Under There That May Have To Be Reset In The Event That The Vehicle Takes A Hard Blow Or Is Jarred (in An Accident). Maybe Running The Swith Wire From There To A Hidden Place Of Your Choosing.
Thought This May Be Better Than Taping Into The Ignition Wiring.
This Way The Vehicle Would Just Crank Over But No Start.
Any Thoughts Or Comments?
Old Aug 28, 2005 | 12:53 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It will still start and run with the inertia switch triggered...until the fuel lines run dry. We did that as a practical joke to a guy one time and he made it 20 miles before it shut off.
Old Aug 28, 2005 | 01:57 AM
3 of 7's Avatar
3 of 7
I wired up a relay on my ignition switch on my old jeep, I put a toggle switch under the dash and when it was armed if you tried to crank the starter it blew the horn(but wouldn't start) ......It used to scare the crap out of me when I forgot it......
Old Aug 28, 2005 | 02:15 AM
cookie88's Avatar
cookie88
FTE Emeritus
I think if you tapped the leads for the IDM relay for a togle switch it should work like a champ.
Old Aug 28, 2005 | 05:17 AM
Kwikkordead's Avatar
Kwikkordead
LOL. I hope he was good natured. Having a hidden camera inside the truck for the last 5 miles would have been priceless.
Old Aug 28, 2005 | 10:14 AM
barebackjake's Avatar
barebackjake
i vote for the idm also. ive got two on-off-on, switches on the dash marked aux lighting and chime bypass. they have to be in the right combination for the truck to run. on my clutch bypass switch i went on-off-momentary. if its in the on posistion there and you push the clutch down it disables the idm and locks the relay out untill you put the idm kill switches to the lock combination then back to normal. i had way too much time on my hands one day.....but i can leave the truck runnin when i go into the 7-11 and if someone tries taking off with it there not gonna get far.
Old Aug 28, 2005 | 12:11 PM
444dieselrod's Avatar
444dieselrod
Starving the injectors of fuel is really they way I wanna stop my truck from getting stolen. I say idm also.
Diesel Rod
Old Aug 28, 2005 | 01:50 PM
4X4 IN REFUGIO
Ok Idm (injector Driver Module) Relay Does Sound Good.
Relay #303 In The Fuse/relay Panel. Pulled It Out And This Is The Result I Want. Cranking But No Start.
Now......to Tap Into The Leads Of It. Pretty Tight Behind It.
Would The Thing To Do Be To Undo The Fuse Panel To Get Better Access To Those Leads Or Is There Another Place To Tap In.
And What Color Wires If Someone Has Done It This Way.
Thanks
Old Aug 28, 2005 | 02:04 PM
barebackjake
i will have to find my book...what year.?? for some reason sigs arnt coming up right now..
Old Aug 28, 2005 | 02:05 PM
barebackjake
ok got it 02.
Old Aug 29, 2005 | 11:24 AM
4X4 IN REFUGIO
Thanks
BUMPING MY THREAD
Old Aug 29, 2005 | 12:09 PM
cookie88's Avatar
cookie88
FTE Emeritus
White with a black trace carries power from the PCM to the IDM relay. Dark green with a light green trace carries power from the relay to the IDM.
Old Aug 29, 2005 | 11:33 PM
SpringerPop's Avatar
SpringerPop
Cookie,
Do you know if the colors are the same for a 2000? I'm cooking up something along this line, but it involves a latching relay, a reed relay mounted behind the plastic instrument panel, a neodymium magnet inside my remote lock fob, and a wire to the "+lock" wire in my driver's door. When I get the round tuit.
Of course, I'll take pictures.
Thanks,
Pop
Old Aug 30, 2005 | 10:30 AM
cookie88's Avatar
cookie88
FTE Emeritus
Yes they are.
Domino
Electrical Systems/Wiring
Apr 7, 2015 06:40 AM
pbjosh
56
Feb 23, 2015 08:29 PM
ag-ford-4x4
Aug 6, 2014 06:06 PM
b6fischer
May 22, 2014 01:29 PM
