Iowa Chapter Join Chapter, Leader:
truck and tractor in maqouketa the 18th
Old 08-29-2005, 07:20 PM
fordsrgrt's Avatar
fordsrgrt
fordsrgrt is offline
they got these going on on the 18th. think i might enter they have a 4wd class .rob do you think the bfg all terrains and with my motor set up it might be worth entering,, running 35"s and 3.73". not sure what class i would be in .
Old 08-29-2005, 08:43 PM
fellro86's Avatar
fellro86
fellro86 is offline
check all the rules before you get too carried away. I couldn't compete with my truck unless I undid some things, and had to have a different bumper, so I didn't bother. You may get put into a class that is too much for you by some simple mods you have, so it may end up the same way as I was...
Old 08-29-2005, 09:23 PM
fordsrgrt's Avatar
fordsrgrt
what were some of the things you had to do and what was wrong with your bumper .i have one of those steel diamond plated step bumpers .like i said not sure about class specs but will maybe see if i can find a flyer and call someone.anyone from around dewitt seen any of the flyers ?
Old 08-30-2005, 10:07 AM
fellro86's Avatar
fellro86
fellro86 is offline
I have an ag hitch bumper, it has to be solid, mine has give for cushion. I also have an electric fuel pump on my diesel, so that wasn't allowed. There was a couple other things that I don't recall now. If you can get ahold of whoever is officiating the pull they should be able to give you the rules. The local pull had theirs listed online.
senix
Fifth Wheel & Gooseneck RV Towing
153
11-10-2012 07:57 PM
powerstroke72
Ford vs The Competition
02-03-2010 10:36 AM
mustange70
Montana Chapter
06-08-2007 08:39 AM
monsterbaby
Iowa Chapter
20
09-06-2005 10:09 PM
grappledad
Offroad & 4x4
08-17-2003 07:20 PM
Quick Reply: truck and tractor in maqouketa the 18th
