On the Road Again
On the Road Again
After about 2 months of sitting in the drive way my '91 Silver Aniversary is back on the road. I had the codes pulled way back when and found that it had hard faults for the EGR valve, EVP sensor, and MAP sensor. I changed out the EGR valve....the most expensive item.....with no success. At this point I got skeptical and let it sit. I didn't feel like spending the money on the other parts only to find that it didn't fix. I had read everywhere that a map sensor wouldn't keep it from running so I didn't suspect it would fix it but finally decided to try it and what do you know. It worked. Woooo Hoooo. Back on the road.
rickthefix
07-05-2008 10:21 PM
