ABS and brake light on
08-19-2005, 11:40 AM
on
Nope, no green gunk. Just brake fluid in the connector side, fouling it out.
11-13-2005, 07:06 PM
on
this might sound stupid but what does the Delta P switch do? our light came on, unplugged the connector at the master, light went off. Local (Too True!) dealer claimed was nothing there.
01-14-2006, 01:08 PM
on
Kinda got a similar problem,abs light(sometimes)goes on and brakes are kinda grabby
mostly when cold.
01-14-2006, 02:46 PM
Quote:
mostly when cold.
Welcome!
Did you do anything with the brakes or sensors right before the lights poped on? (Flush brakes, replaced pads or calipars, ect.)
Year? Millage? Engine? AWD?
10-06-2006, 10:23 AM
on
I had the same problem with Delta P switch. I pulled the switch out, and did notice some of that green gunk you were talking about...I cleaned it out with cotton swab...should I be concerned?
10-06-2006, 12:27 PM
on
Hi Chris&laurie
Welcome to our FTE forum
10-07-2006, 01:10 AM
Chris,
That corrosion will build up with time, so you should just count on ding this cleaning at least once a year, unless the light comes up sooner.
09-27-2016, 07:50 AM
on
How do the connectors come apart at the bottom of the master cylinder reservoir? Don't want to break anything.
Adambomb945
15
11-02-2017 08:49 AM
rlvbronco
1978 - 1996 Big Bronco
09-14-2016 05:12 PM
Cummins7mm
03-23-2016 09:49 PM
Cummins7mm
03-21-2016 08:01 PM
justcruzin125
17
03-01-2016 06:44 PM
abs ,
aerostar ,
brake ,
ford ,
key ,
led ,
lightsgo ,
on1990 ,
onford ,
proportioning ,
schematic ,
system ,
truck ,
valve ,
wwwasashoporgautoincjan99techtipshtm
