How to remove Overdrive Switch?
Guys,
When I bought my truck it had the common problem of the OD switch not working. Just got around to pulling it apart today to find my broken wires. Now here's the problem. The wires broke so close to where they go into the shifter shaft that there's no way I'll be able to splice them. So I thought, no biggie, I'll just pull the end of the handle/switch off and splice them and run new wires down the shaft. How in the heII do you get the switch off? I've tried twisting, pulling, prying with a flathead in the little slot on the back side. I can't get this thing to even budge. I'm sure it's something I'm just missing, but I can't get it off. Thanks in advance.
DDPJ
10-04-2014 06:51 AM
RangerDude17
01-25-2014 04:38 PM
Jimmyrig
10-31-2013 10:46 AM
