How do these edge insight numbers look
Installed my new edge isight cts monitor few days ago and wondering how these numbers look. Truck is a 1997 f350 with a 6 inch skyjacker lift on 315/75/16 nitto tires. Nothing in the bed and no trailer. After driving 10 miles on the freeway here is what i got.
Eot 210
Tft 157
Map psi 17
Ebp 6
Boost3
Wcg% 0
70 mph
Tps 40%
Rpm 2150
After getting off the freeway, going up the ramp at wot i got ebp 8 and boost 11.
Also, while driving on the city streets on the way home, sitting at a few red lights, my eot dropped to 195. So hows everything look? Thx
Eot 210
Tft 157
Map psi 17
Ebp 6
Boost3
Wcg% 0
70 mph
Tps 40%
Rpm 2150
Yeah what Nate said. Your EOT may be a little higher due to running bigger tires and the engine working a bit harder? Mine stays right at 199-200 when just driving around town or down the freeway. I suffered the same boost issues. I found the inlet to turbo was loose and the hoe to the MAP had a pretty big hole in it. I was at 8 WOT, but after fixing those two issues, I can get it up to 15 WOT, but I am still not happy with that. MY up pipes are new and no leaks that I can see. Might just be a tired turbo. I am guessing a nice new TS Chip will change all of that
But yeah, those numbers look good. It's amazing to me how cool my tranny runs. Even towing 10,500# up a 6% grade, I never got over 160.
My guess is that the scanner is looking for the wastegate control on a 99+ (Super Duty) 7.3. The OBS doesn't have one, so I'm guessing you'll never see it go above 0% unless the scanner confuses that output with something else the PCM is sending.
BBslider001
51
03-02-2014 12:25 PM
