Bronco II Ford Bronco II
dumbest ? ever
Old Aug 4, 2005 | 07:39 PM
nija_face's Avatar
nija_face
Question dumbest ? ever
i really feel like a short bus but im not really that mechanically wise so please give me a few pointers. i recently(1st time) put my 1989 bronco deuce in 4 wd drive and i cant get it out of 4wd for the life of me. im not even sure if it needs to be in park or neutral. all i know is the last time i tried to shift it to 2wd it stopped in the road and woudnt drive till i shifted back to 4wd. its almost impossible to push the stick back to the 2wd position can someone please tell me how to make it all normal again. ive been driving for to long in 4wd now and it really is limiting the distance i can travel.
Old Aug 4, 2005 | 07:43 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 5, 2005 | 03:45 AM
GrayRanger4x4's Avatar
GrayRanger4x4
First thing it to make sure your hubs are not locked in {if you have manual hubs}then you will not damage your front end.If you got auto hubs then dont drive it on any hard survices {spelling}.You do need to stop the truck and with the tranny in park or neutral.pul the 4x4 shift lever towards your feet then pull back till you feel the next notch,this should be 2 hi.the next notch is neutral,then back one more is 4low.I would crawl under the truck find the lickage and make sure its not bent or that something is not hung in it.Also spray it real cood with a good spray lube.hope this helps.
Old Aug 5, 2005 | 05:50 AM
RomerB2's Avatar
RomerB2
I'm glad I have an auto case lol. But you should put it in neutral and it should slip in.
strat875
Feb 25, 2023 08:30 PM
steveg_nh
Mar 12, 2017 11:58 PM
Emithez
Feb 18, 2017 12:19 PM
mxer0022
53
Apr 25, 2015 12:39 PM
stuckinsnow
Feb 11, 2004 02:32 PM
