VIN Help Needed!
Old 08-02-2005, 06:36 PM
JS63FV's Avatar
JS63FV
JS63FV is offline
Smile VIN Help Needed!
Hi fellow Ford fanatics! I'm new here (but not to Fords). I just aquired a nice 1963 Econoline Club wagon, and need some help decoding the VIN. Here goes:
WB C Model Body Trans Axle
090 E E130 89D A 01
Warranrt info is:
E13TH367587
Thanks, and I am glad that I found y'all and this forum!!!!!
Jerry
jerryS@pdalightingandsound.com
Old 08-02-2005, 09:42 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Jerry, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-02-2005, 09:59 PM
66gpw's Avatar
66gpw
66gpw is offline
Ok here goes. The E13 is model E130 Deluxe Club Wagon.
The T says you have a 170cid 6 cyl.
The H means it was built at the Lorain assembly plant.
The remaining numbers mean the consecutive unit number, meaning which month and what number of unit that was built that month.
Does that help any? Have fun and enjoy driving your wagon.
Old 08-02-2005, 10:05 PM
66gpw's Avatar
66gpw
66gpw is offline
The rest I forgot. The color code E represents Oxford Blue metalic.
A89 says Standard Van.
A on the trans means c4 Automatic.
Axle 01 says ratio of 3.50
Old 08-03-2005, 02:40 PM
jschira's Avatar
jschira
jschira is offline
E-series did not get the autos in 1963. 3-speed only.
They certainly did not get the C-4 auto in 1963.
89D is the Club Wagon. 2923 produced in 1963
I'm not sure about the engine and what the "T" means for sure. There were only 2 engines available in 1963, the 144 and the 170. Look at the door tag. The engine HP will be listed. The 144 had 85 HP, the 170, 101 HP.
In 1963, the 144 was painted Ford Medium Blue, the 170, Ford Red.
Old 08-03-2005, 05:02 PM
jschira's Avatar
jschira
jschira is offline
My '63 has the "T" engine code and it's a 144.
Old 08-04-2005, 01:12 AM
66gpw's Avatar
66gpw
66gpw is offline
I have a manual for 61 and 65 Econolines. It shows an S for the 144 and aT for 170 6cyl. I know I read the trans code from my 65 manual and it showed that to be an Automatic. I will admit I myself question this, for I beleive the Automatics came out in 65 or 64 but not prior to that. So I would stand corrected then.
Jshira If yours says T for engine and you have a 144. Has the engine been changed on your econo at some time?
I have 2 64's and 2 67's and one is a 4 spd on a 170 engine in the 64 van.
Anyways I do not have a manual on 63 and I deciphered what I could from the 2 manuals I do have.
Old 08-04-2005, 06:30 AM
jschira's Avatar
jschira
jschira is offline
Here is the 1963 Econoline brochure.
http://www.falconman.com/fullbrochur...llbrochure.htm
The auto and 4-spd. were not available until 1964. The only tranny available in 1963 was the 3-spd. Tranny code A.
The 144 had 85 HP. The 170 had 101 HP. The door tag on Econolines lists the HP. My door tag says 85 HP and I have a "T" engine code. Based on that, the "T" means the 144. Even if the engine has been switched, the tag would still be accurate.
Old 08-04-2005, 09:02 AM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
here you go guy's, straight from the econoline registry!
E13 = Falcon Deluxe Club Wagon
T = 170 engine
H = Lorain assembly plant
367587 = December 1962 serial # - 1963 model
090 = wwheelbase
E = Viking Blue paint
E130 = Falcon Deluxe Club Wagon model
89D = Falcon Deluxe Club Wagon body
A = 3 speed transmission
01 = 3.50:1 light duty axle (7-1/4 inch)
? = missing sales district code
jim
Old 08-04-2005, 09:28 AM
jschira's Avatar
jschira
jschira is offline
I have to agree with you. My bet would have been that the "T" code meant the 170.
But, I am having trouble reconciling having both the "85 HP" rating and the "T" code on my door tag.
Old 08-04-2005, 10:42 AM
66gpw's Avatar
66gpw
66gpw is offline
Thanks Jimbare. and Jschira. I have quite soon knowledge on these vans, but there is always room for more. One would be to eventually learn what disc brakes can be setup on these vans and trucks.
Looking forward to the day I restore the one truck and the customizung of the other. Thanks again.
Old 08-04-2005, 10:47 AM
jschira's Avatar
jschira
jschira is offline
I just sold my van, so for me, just something to file away.
I told the guy who bought mine that it had the 144. If it has the 170, he got a little bonus. It will run 55-60 mph all day long, which is what is really important.
Jerry's red Ford
Ford Truck Parts for Sale
12-10-2014 11:56 PM
jerry olmsted
07-22-2011 08:27 AM
jerry hardesty
12-13-2010 02:14 PM
crashnjerry
1961 - 1963 F100 Unibody
01-27-2008 02:02 PM
Quick Reply: VIN Help Needed!
