Seat Interchange
Old Sep 26, 2007 | 10:49 PM
biz4two's Avatar
biz4two
Arrow
Originally Posted by RangerTuff05
so if i have a 1977 ford f250 I can put the seat from my 95 f150 in it. Its the one with the big fold down armrest that can be pushed up for a third seat. Also keep in mind that i have the in cab fuel tank. I want bucket seats but don't know what would work the best
Agree with Mil1ion! I have seen many of those conversions...and they always improve the interior...IMO.
Good luck...
biz
Old Sep 27, 2007 | 12:29 AM
czaroc's Avatar
czaroc
I know the buckets out of the Broncos will fit into the SuperCabs. Have to put some weld-nuts on the floor, but not too hard... The brackets fit right up.
Old Sep 27, 2007 | 04:14 AM
RangerTuff05's Avatar
RangerTuff05
so you don't think ill have problems putting those seats into my truck even with that gas tank
Old Sep 27, 2007 | 06:29 PM
hp246's Avatar
hp246
I have a 76 F-100. I measured the bolt holes for the seat mounts center to center. Fron to back they are 15,5 inches. The width is 42 inches. I recently bought a bench seat from the mid 90s, and the measurements are exactly the same.
Old Oct 25, 2007 | 01:48 PM
ChaseTruck754's Avatar
ChaseTruck754
Back from the dead again...
What broncos? 78-79 or the 80's or 90's?
I am looking at putting a split type bench from a 95 or so in my 74 crew and I'm pretty sure the split benches have 8 bolt in points instead of 4 like a basic bench. I would assume (hope is more like it) that these mounting points are the same as the buckets were/are and that they will line up.
Is my assumption correct? Anybody tried a split/sliding bench?
Old Jan 11, 2008 | 07:06 PM
hines182's Avatar
hines182
i always thought the '61-'72 seats interchanged with the '73-'79s, too.. is that correct or am i mistaken?
Old Jan 11, 2008 | 07:47 PM
MBBFord's Avatar
MBBFord
I believe you are right, but there are not very many 60s trucks in the junkyard with good seats still in them to try and use them.
Old Jan 26, 2008 | 01:18 AM
hines182's Avatar
hines182
so then there's no reason you couldn't put these newer seats in a '64 ford, too. right?
Old Jan 26, 2008 | 09:04 AM
MBBFord's Avatar
MBBFord
I'm not sure about the pre 73 models, but IF I had to guess, I'd say you could.
Old Jan 26, 2008 | 01:48 PM
tude's Avatar
tude
this is a set of seats out of a GM....not sure what though. very comfortable. ill be swapping them out for a set of electrics out of a 78 lincoln all electric and leather, same color.
Old Jan 26, 2008 | 08:30 PM
markdeimling's Avatar
markdeimling
I put some 2003 F250 seats in my 77, it is not a bolt in project. I had to make a custom frame out of box steel. It was a real pain. They will sit higher than the original seats so if you are tall or have problems getting in then they might not be a good option.
Old Jan 26, 2008 | 09:12 PM
phatkat's Avatar
phatkat
seat
I have a friend that took a bench seat out of a 96 larit and took the seat rails off of his 78 and bolt them together and they fit great and was comfortable.
Old Feb 23, 2008 | 11:25 PM
  #28
funkdogge's Avatar
funkdogge
what bucket seats would bolt into a 78 standard cab? the posts I saw all say super cab.
Old Feb 24, 2008 | 08:32 AM
  #29
MBBFord's Avatar
MBBFord
You will need the brackets the seats bolt onto in the first place.
A 78 79 Bronco would be a good place to get those brackets, but the seats aren't the greatest, so once you have the brackets, you can get just about any 70s-maybe90s bucket seats from a truck or car.
I have bucket seats out of a 70s model LTD, and they mounted to my brackets perfectly.
Old Feb 24, 2008 | 06:54 PM
  #30
funkdogge's Avatar
funkdogge
cool so it looks like the bracket mounts from fords are more or less universal?
