wet sanding
Old Jul 31, 2005 | 09:47 PM
fordboy_52's Avatar
fordboy_52
wet sanding
i have a black ranger and my paint got attacked by a dog and id like to fix it... someone told me if u can click it u cant fix it, and my scratches arnt that deep. i was thinking about wet sanding it and then buffing it with rubbing compound.. any ideas?
Matt
Old Aug 1, 2005 | 06:19 PM
triton_2002's Avatar
triton_2002
You should try the least aggressive method first. Try swirl/scratch remover first, if that doesn't work, go with a more abrasive method, like wet sanding. After wet sanding you probably need to use a glazing compound and buffer to get the shine back.
Old Aug 3, 2005 | 01:30 PM
GWall's Avatar
GWall
Wet sand with a very fine sand paper, 1000 to 2000 grit, then buff with a mild polishing compound. If you can remove the scratch without going through the clear coat it will look as good as new.
