Engine temp
Old Jul 26, 2005 | 11:34 PM
phish555's Avatar
phish555
Engine temp
I have a 94 f350 turbo diesel. It has a coolant temp gauge and an engine temp light. I don't understand why it has both but thats ok. My problem is that sometimes my engine temp light comes on but the gauge reads "normal". It usually does this when I am running my ac. I can tell the engine is not running hot and i belive the "engine temp" light sensor is going bad. I can not find the right part to replace the sensor. I special ordered one but it was too small. It mounts to the left front side of the block right above the exhaust manifold. Anyone know the part number for this sensor?
phish555
1994 F350 turbo diesel crew cab
Old Jul 26, 2005 | 11:49 PM
PLC7.3's Avatar
PLC7.3
Your engine temp light is on the head and denotes when the temp reaches 244*F. I would suggest you check the wire and see if there is an intermittent short to the block.
