Brake light
Old Nov 21, 2002 | 01:22 PM
GT77v8ford's Avatar
GT77v8ford
Brake light
:-X12 Just a quick question. What typical things cause the brake light to come on and stay on and what are the typical fixes.
Old Nov 21, 2002 | 01:31 PM
sparky's Avatar
sparky
Brake light
Switch above the brake pedal is probably sticking or needs adjustment. Very easy. If you look at the pedal arm, you will see the switch and see how easy it is too adjust.
Sparky
Old Nov 21, 2002 | 03:01 PM
Mil1ion's Avatar
Mil1ion
Brake light
I thought it was the imbalance in the hydraulics from a leak in the Brake fluid system.
The brake differential valve warning light.
Dennis
F.T.E. Assistant Administrator
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 21, 2002 | 03:22 PM
sparky's Avatar
sparky
Brake light
That is ok I thought it was the brake lights staying on.
I guess if it is the brake light on the dash then it could be a fluid leak in the brake system, a brake warning switch that needs reset, maybe the switch is stuck, the possibilities are many.
First check for fluid leaks, then if none are found try resetting the switch on the proportioning valve. I have also seen this caused by defective master cylinders, but usually the light is accompanied by a soft pedal.
So if there are no fluid leaks and the pedal feels fine I would bet that the switch needs reset.
Sorry for the misunderstanding
Sparky
Old Nov 21, 2002 | 05:14 PM
1972 Ford Thunderbird 429 V8's Avatar
Brake light
