Dana 60 - Sterling 10.25 swap
First of all I would have searched this topic before posting.... but I couldn't figure out where to do it.
I'm researching swaping out the Dana 60 rear of my '79 F-350 4x4 SC/LB with a Sterling 10.25 out of a late model F-350. Does anyony have experience? Are there many modifications required to the 10.25?
Thanks for your time.
Adam :-X12
Adam :-X12
I am doing the same thing and as far as I can tell its A bolt in swap. Im already running the late model springs etc and just aquired a rear. I cant do the swap for 2 more weeks though so I cant tell you for sure. But a freind of a freind has done it several times. THE 10.25 is much stronger thats what im after.
I just got through swapping out my rear 60 for an 85 f-350's sterling. The spring perches bolted right up, the shock mount work fine, only thing ou have to do is take your dana 60 brakeline t-fitting and put it on the sterling so you can bolt up your brakehose. Everything worked out great, just beware cause that sterling is a heavy mother. It must weigh 100 lbs more than the little 60. Good luck with the swap
TURBO
09-29-2016 12:44 AM
infinite-foamies
03-01-2016 10:23 AM
Tabaker
10-13-2004 06:08 PM
DannyP
13
02-08-2001 08:49 AM
